Currently in Beta
You don't need to spend hours packaging your algorithms anymore thanks to Allgo. End users can immediately use your application.
We are using Linux container technology to run your applications. They can be launched several years after the initial deployement without any upgrade of your source code.
Thanks to our easy to use HTTP REST API, you can do your own scripts using our platform.
